ALL PRO SOLUTIONS USB-20 STANDALONE MANUAL USB DUPLICATOR - 20 TARGETS
The M-USB Series USB duplicators easily and reliably create multiple copies of your USB cards without a computer or cumbersome software. Each USB channel has dedicated copy throughput of 33MB per second. Asynchronous copy allows each channel to function independently and copies directly from 128MB of built-in memory so there is no need to start and end a copy cycle at the same time. Source Analysis feature identifies the content on the master and intelligently copies only the data to speed up copy cycle. Fast reliable convenient and cost-effective to operate M-USB Series USB duplicators help you to get more done in less time!
Standalone solution; no PC or software is needed.
Support Asynchronous copy mode.
Unique Source Analysis feature.
Up to 1980MB/min copy speed per channel.
Easy to use cost-effective to operate.
Real-time display of detailed information.
No warm-up or cool-down required.
Heavy-duty construction built for daily operation.
Standalone Manual USB Duplicators Specifications:
Operating Type: Stand-alone (No PC Required).
Targets: 20.
Supported Media: USB Drive (USB Model).
Transfer Speed: Up to 1980 MB/min.
Buffer Memory: 128 MB.
Copy Mode: Synchronous or Asynchronous.
LCD Display: 2 x 16 Backlit.
Power Requirements: 115V or 230V.
Operating Temperature: 41°F ~ 122°F.
Operating Humidity: 15% ~ 90%.
Regulations: FCC CE.
Price: 3110.18
